Honda XR 650L, a moto que eu queria no brasil
HONDA XR 650L 2019 - A moto que eu gostaria que viesse ao brasil
http://powersports.honda.com/assets/..._Street_06.jpg
http://powersports.honda.com/assets/..._Street_01.jpg
http://motorcycleshonda.com/wp-conte...rs-550x300.pnghttp://powersports.honda.com/assets/..._Street_05.jpg
Model |
XR650L |
ENGINE |
Type |
644cc air-cooled, dry-sump, single-cylinder four-stroke |
Valve Train |
SOHC; four valve RFVC |
Bore x Stroke |
100.0mm x 82.0mm |
Compression Ratio |
8.3:1 |
Induction |
42.5mm diaphragm-type CV carburetor |
Ignition |
CD w/ electronic advance |
Starter |
Electric |
Transmission |
Five-speed |
Clutch |
Multiplate wet |
Final Drive |
#520 O-ring sealed chain; 15T/45T |
SUSPENSION |
Front |
43mm air-adjustable leading-axle Showa cartridge telescopic fork w/ 16-position compression damping adjustability; 11.6 in. travel |
Rear |
Pro-Link Showa single shock w/ spring preload, 20-position compression damping and 20-position rebound damping adjustability; 11.0 in. travel |
BRAKES |
Front |
Single 256mm disc w/ twin-piston caliper |
Rear |
Single 220mm disc w/ single-piston caliper |
TIRES |
Front |
3.00-21 |
Rear |
4.60-18 |
MEASUREMENTS |
Rake (Caster Angle) |
27° |
Trail |
102mm (4.0 in.) |
Length |
86.2 in. |
Width |
33.7 in. |
Height |
49 in. |
Seat Height |
37.0 in. |
Ground Clearance |
13.0 in. |
Wheelbase |
57.3 in. |
Fuel Capacity |
2.8 gal., incl. 0.6-gal. reserve |
Color |
Red |
Curb Weight* |
346 lbs. |
