Olha a $#@%$# que eu comprei. Comprei por R$100,00. No site o mesmo modelo novo custa $469.41 dolares!! So o motor separado custa $277.50 doletas :0_0: :0_0:
É americano, com motor japones. Nem preciso comentar que é todo bem feito.
site do fabricante: http://www.goped.com/
ficha técnica.
Engine Model G23LH
Engine Description Single Cylinder, Two Stroke, Air Cooled
Engine Displacement 22.5cc
Engine Power 1.2 HP
Engine Ignition Electronic
Engine Cutoff Handlebar Kill Switch
Carburetion Walbro
Transmission Direct Drive
Fuel Gas & 2 Cycle oil @ 40:1
Fuel Capacity 1 Liter
Fuel Economy 100 mpg
Max Speed 20 mpg
Cruise Speed 15 mpg
Min. Speed 2 mpg
Dimensions L-34" W-13" H-42", Folded L-34" W-13" H-14"
Dry Weight 20 lbs
Max Load 400 lbs
Wheel Type 6" Non-Pneumatic Go-Active™ Rubber
Front Brake Wheel Caliper
Rear Brake Compression
Additional Features *Oldest Product in our line up with a huge selection of aftermarket parts.
*Extremely Efficient drive system with only one moving part.
*Converts to a standard kick scooter by disengaging the drive.
*Lightest weight and compact design.
Aircraft grade aluminum and Comely construction
[img=http://img407.imageshack.us/img407/7163/dsci0002xa7.th.jpg]
[img=http://img186.imageshack.us/img186/3130/dsci0003tu3.th.jpg]
[img=http://img402.imageshack.us/img402/1669/dsci0005ob8.th.jpg]
[img=http://img295.imageshack.us/img295/2432/dsci0006pa0.th.jpg]
[img=http://img80.imageshack.us/img80/8466/dsci0009ow6.th.jpg]
Responder com Citação
