não sei se já postaram
SPECIFICATIONS
TECHNICAL SPECIFICATIONS:
Overall Length: 2,240 mm
Overall Width: 880 mm
Overall Height: 1,110 mm
Wheelbase: 1,520 mm
Ground Clearance: 150 mm
Seat Height: 685 mm
Dry Mass: 140 kg
Fuel Capacity: 12 litres
ENGINE:
Engine Type: Air-cooled, 4-stroke, 65 degree V-twin, SOHC
Bore x Stroke: 44 x 40.9 mm
Max Power: 13.3 PS (9.8 Kw) @ 10,500 rpm
Max Torque: 9.8 Nm @ 8,000 rpm
Piston Displacement: 124 cc
Compression Ratio: 10.3 : 1
Carburettor: Mikuni BDS26
Lubrication: Wet sump
ELECTRICAL SYSTEM:
Ignition Type: Digital electronic
Starter System: Electric
TRANSMISSION:
Clutch: Wet multi plate
Transmission: 5-speed constant mesh
Drive System: Chain
CHASSIS:
Front Suspension: Conventional, oil damped, coil-sprung telescopic
Rear Suspension: Twin shock absorber, adjustable spring preload
Rake/Trail: 31.7 degrees / 120 mm
Front Brake: Single piston caliper, 275 mm single disc
Rear Brake: 130 mm drum
Front Tyre: 90/90-18
Rear Tyre: 130/90-15
Responder com Citação
