Esta é a primeira moto da Honda 125cc com IE, é fabricada na Índia com o nome de Glamour. O motor é uma M, mas promete 65 km/l .
O melhor de tudo, já vem com farol de Falcon, o coisa horroroza. |
Type Air cooled , 4 - stroke single cylinder OHC
Displacement 124.8 c.c
Maximum Power 6.72 KW ( 9 BHP ) @ 7000 rpm
Maximum Torque 10.35 N-m @ 4000 rpm
Bore x Stroke 52.4 x 57.9 mm
Compression Ratio 9.2 :1
Fuel System
Programmed Electronic Fuel Injection { PGM-FI }
Starting Self Start / Kick Start
Idle speed 1500 rpm
Ignition FTi - Full Transisterised Ignition
Clutch Multiplate wet
Gear box 4 Speed constant mesh
Chassis Type Tubular Double cradle Type
SUSPENSION
Front Telescopic Hydraulic Shock Absorbers
Rear Swing Arm with Hydraulic Shock Absorber
BRAKES - FRONT
Disc 240 mm Dia ; Pad - Non Asbestoes type
Drum Internal Expanding Shoe Type ( 130 mm ) ; Liners - Non Asbestoes type
BRAKES - REAR
TYRE SIZE
Front 2.75 x 18 - 42 P / 4 PR
Rear 3.00 x 18 - 52 P / 6 PR
Battery 12 V - 2.5 Ah ( Kick ) / 5 Ah ( Self )
Head Lamp 35W / 35W - Halogen Bulb ( Multi-Reflector Type )
TYRE PRESSURE
Front(solo/pillion) 1.75 Kg / cm² / 1.75 Kg / cm²
Rear(solo/pillion) 2.25 Kg / cm² / 2.50 Kg / cm²
Fuel tank capacity 12 Ltrs ( Min )
Reserve 1.5 Ltrs ( Approx)
Length 2005 mm
Width 735 mm
Height 1070 mm
Wheelbase 1265 mm
Ground clearance 150 mm
Kerb weight 125 Kg ( Kick ) / 129 Kg ( Self ).
